TopN performance statistics
  • dialp
    • Mar 2018
    I'm looking at using Zabbix to monitor routers and switches in our network. I've got a testbed Zabbix 3.4 instance installed and I've been able to use out of the box templates to monitor some routers and switches.
    I need to be able to report on the TopN interface's utilization, discards, or errors across all routers/switches. What would be the best way to achieve this in Zabbix? How difficult would it be to pull the underlying data used to create the graphs and produce a tabular report?
    Any guidance would be greatly appreciated. Thanks!
