Multiple hosts with single zabbix agent
  • philthynz
    • Jun 2016
    • 27
    Hi Everyone,
    Can the zabbix agent active checks on a single agent also do the checks for multiple hosts? Like having multiple hosts from one agent? I tried adding multiple hosts in Hostname= in the agent config file. But it won't accept that. I wouldn't want to have an agent for every host if that can be avoided. The environment is a hosted zabbix server and the agents in lxc containers that collect snmp etc...
  • salai
    • Nov 2020
    • 27
    Did you find out the answers for this question?
    • gofree
      • Dec 2017
      • 400
      Hostname= for active checks is kinda identification ( or pairing the zabbix agent installed on a particular system ) of the zabbix agent on OS and host created in the frontend ( eg databased ). So simple answer is no, what you trying to achieve will not work and its kinda impossible to work ( how should the agent connect to other hosts just by specifying their name, its not build like this ).
      What you can do especially if youre interested in snmp is collect those metrics from zabbix proxy ( single point ) and poll ( passive checking ) hosts ( defined in frontend eg. zabbix db ).
      • Nel23FX
        • Feb 2021
        • 10
        Check your host with SNMP so instead of ZabbixAgent to avoid installing agent on each hosts.
        Zabbix Agent is a clientside programm. So by definition one Agent = one Host.
        It's curious to want an agent for multiple machine. But think an host can have multiple hostname (localhost, machine, machine.domain, host.workgroup)
        Am I right?
          • 5002
          As this thread was created, there was no such option... but with 5.2 you can have multiple hostnames in agent config. I think it even does autoregistration for multiple hosts, if those are described there and you have autoreg actions in place.
          Hostname no Set by HostnameItem List of comma-delimited unique, case-sensitive hostnames.
          Required for active checks and must match hostnames as configured on the server. Value is acquired from HostnameItem if undefined.
          Allowed characters: alphanumeric, '.', ' ', '_' and '-'.
          Maximum length: 128 characters per hostname, 2048 characters for the entire line.
          • Brain2000
            • Aug 2024
            • 16
            It would be really cool if the Zabbix agent could have a "cluster" mode, where it would enumerate the IP addresses every so often and query the Zabbix server for entries that matched. That way a cluster could fail over and Zabbix Agent Active tests would be able to follow the virtual host around.
              • 5002
              You should be able to tie agent as a resource to a cluster, so it will be started up together with your other cluster resources (including that virtual ip), and then it will be started always in the same host where your cluster resource currently is...
              • Brain2000
                • Aug 2024
                • 16
                How many agents can you run simultaneously?
                  • 5002
                  how many you need? point is to run them on different ports.. So keep your local agent at default 10050 and start up another at 11050, for example, and third on 12050 etc... each of them needs their own config file.
                  • Brain2000
                    • Aug 2024
                    • 16
                    I would use one per set of cluster resources so they could be started/stopped/moved between nodes. For example, I have one cluster with four SQL instances that can move independently from each other, so in that case it would need 5 agents (one for each SQL instance and one for the node itself).
                    Sounds like that is a feasible direction to go.
