My company makes extensive use of Graphite. Is there a way to integrate Zabbix with Graphite, so that performance data can be sent to Graphite and not just recorded in the Zabbix DB?
Zabbix & Graphite
How far did you get with this? im trying to do the same thing. found someone talking about pulling the two together: https://github.com/rtbkit/rtbkit/wik...using-graphite -
You are the first to respond. I actually had put zabbix aside in my evaluation process because it didn't have a 64 Bit windows agent until version 2.2.1 12/9/13. I was evaluating 2.2.0 at the time..
Zabbix is now back in my evaluation queue and I will be looking into it again in 2 weeks.
-RickComment
You can use graphite2zabbix project to put graphite data to zabbix automatically.
Integration is very easy, only create zabbix items with application name 'graphite' and execute script every minutes via cron.
LIKE.
Nexenta has recently released a collectd-graphite analytics toolkit
GitHub is where people build software. More than 225 million people use GitHub to discover, fork, and contribute to over 800 million projects.
i intend to use this connector to get data into Zabbix where it's more useful to me (as opposed to Grafana)Comment
