zabbix_get fails
  • stepassia
    • Feb 2018
    • 27
    zabbix_get fails
    Hi to all, I've a simple userparameter conf file:
    UserParameter=barman.s3.cspgres2.basebackup,cat /var/log/barman/cspgres2.basebackup.s3.status
    UserParameter=barman.s3.cspgres2.wal,cat /var/log/barman/cspgres2.wal.s3.status
    The files contain 0 or 1.
    With zabbix_agentd -p I can see:
    barman.s3.cspgres2.basebackup [t|0]
    barman.s3.cspgres2.wal [t|0]
    But from zabbix server with zabbix_get -s 192.168.**.**-k "cspgres2.wal.s3.status"
    I get ZBX_NOTSUPPORTED: Unsupported item key.
    Any idea?
    Stefano
  • Atsushi
    • Aug 2013
    • 2028
    What you are configuring is the UserParameter of the following key:
    - barman.s3.cspgres2.basebackup
    - barman.s3.cspgres2.wal
    'cspgres2.wal.s3.status' specified by the argument of the zabbix_get command does not exist.
    Please execute as follows.
    zabbix_get -s 192.168.**.**-k "barman.s3.cspgres2.wal"
    • stepassia
      • Feb 2018
      • 27
      Ops... typo! Thanks
