Pre-processing Trim, Regex or String?
  • Clontarf[X]
    • Jan 2017
    • 80
    As the topic says, I have been experimenting and I can't find the answer to this.
    My value is:
    MSCluster_Network.Name="Something"
    I want Something, so I apply the following trim pre-processing;
    Left Trim: MSCluster_Network.Name="
    Right Trim: "
    My question: Is is a literal character/string match? Do I need escaping? Do I need regex? I can't find this documented anywhere.
    Any info appreciated.
  • aigars.kadikis
    • Mar 2018
    • 208
    You can extract the content inside double quotes using Regular expression grouping "(.*)"
    • Clontarf[X]
      • Jan 2017
      • 80
      Thanks very much. I wasn't sure if it supported groups but it makes sense in hindsight. Thanks again.
      Would still like some clarification on trim if someone has information
      • nameuser
        • Apr 2018
        • 39
        How to trim line break simbol?
