Key (CPU Usage)
  • Tialisson Mazarem
    • Mar 2018
    Key (CPU Usage)
    Hello! I am having problems with the key system.cpu.util [<cpu>, <type>, <mode>]. I create the item to monitor cpu usage, but it does not collect data and says unsupported. Agent Zabbix runs on a Windows PC.
  • Atsushi
    • Aug 2013
    • 2028
    The parameters of the item key is incorrect.
    The argument cpu, type and mode means that you can specify those values.
    Although it is described in the manual, specify the values as necessary for each.
    Example:
    ⇒ system.cpu.util[0,user,avg5]
    • Tialisson Mazarem
      Tialisson Mazarem commented
      Hello, Atsushi! Thank you for orienting me. I did as you indicated and I used it this way (system.cpu.util [0, user, avg5]) but did not get results. The status continues as unsupported. I have tested these parameters on more than one host, they run Windows and I use monitoring through zabbix agent.
