unable to monitor WebLogic
  • boniface
    • Dec 2013
    Running on a single host WebLogic, Zabbix, Java gateway. Everything is of the latest stable version and supposed to be connecting through 127.0.0.1.
    zabbix_server.conf:
    JavaGateway=127.0.0.1
    JavaGatewayPort=10052
    StartJavaPollers=5
    Additionaly added in server configuration JMX interface on 127.0.0.1:10052.
    I fully restarted the server after configuration, but JMX indicator is still red and zabbix_java.log (attached) contains errors:
    2013-12-16 15:47:02.234 [pool-1-thread-4] WARN com.zabbix.gateway.SocketProcessor - error processing request
    com.zabbix.gateway.ZabbixException: bad protocol header: 4A 52 4D 49 00
    2013-12-16 15:47:02.237 [pool-1-thread-2] WARN com.zabbix.gateway.SocketProcessor - error processing request
    com.zabbix.gateway.ZabbixException: java.io.IOException: Failed to retrieve RMIServer stub: javax.naming.CommunicationException [Root exception is java.rmi.ConnectIOException: non-JRMP server at remote endpoint]
    btw, I know also there is a bug, which is still unresolved, but not sure this is the real cause.
  • boniface
    • Dec 2013
    the solution was found
    Generally, the idea is to access WebLogic runtime mbeans through the JVM's MBean server, not through the WebLogic's native one. How to make so? There is a nice guide here, but it started working fro me just when I added to the args:
    -Djavax.management.builder.initial=weblogic.managem ent.jmx.mbeanserver.WLSMBeanServerBuilder
    -Dcom.sun.management.jmxremote.rmi.port=9999
    Hope this helps.
    • Bruno Carvalho
      • Oct 2014
      • 32
      See if my article helps you: http://brunocarvalho.net/blog/2016/0...me-com-zabbix/
