Newbie help much appreciated
  • ochocobull
    • Nov 2013
    Good morning,
    I recently installed Zabbix on Debian 7 (Wheezy) clean install no desktop environment and ssh server only. Followed the Zabbix documentation and everything is up and running with a nice clean 2.2.1 front end.
    Now the painful part. I am simply looking to monitor the total data usage on several UBNT endpoints. This appears to be a much bigger issue then I could have expected. It appears the problems is with the dynamic MIBs but to be honest I have no idea. I have scoured the forum here looking for templates and was unable to find what I am looking for. If someone could point me in the right direction I would be extremely grateful.
  • tsalle
    • Oct 2012
    • 79
    Data usage ?
    What do you mean by monitoring the data usage ?
    Network traffic ?
    You can use the "Template SNMP interface" for that..
    Thierry.
    • ochocobull
      • Nov 2013
      Network traffic ?
      Thierry.
      Hi Thanks for the reply. What I am actually looking for is the total amount data used over a given time to run reports against. I don't believe this is the same as data traffic but I could be wrong. In using some of the UBNT templates and scripts I have found I am able to track the WLAN rate but not traffic.
