Using Zabbix External Script to show a .jpg image
  • liquidsnake1989
    • Oct 2014
    • 10
    I'm running Zabbix 3.4 on Centos 6.9 Final.
    I'm using Zabbix to monitor Camera systems (CCTV), and see if the IP camera's are still online, what their CPU load is, etc.
    I made an External script that uses ffmpeg to create a .jpg image from an RTSP stream. So far so good.
    However, I would like to use this external script on the Maps I created, but when I click on the external script I made, it puts the HTML <img> tags in plain-text on the script window.
    To make troubleshooting easier, I simplified the script so that it now only echo's a simple <a href>, but that doesn't work either.
    The script I currently use contains this:
    #!/bin/bash
    echo \<a href=\"https://www.zabbix.com\"\>Zabbix website\</a\>
    The output in the Script window is:
Name:	script window.jpg
    When I inspect the element, it shows:
Name:	inspect element.JPG
    Why does it output the HTML tags in plain-text? Is there a way I can put HTML code there, such as an <a href> or <img> ?
    Thanks in advance!
  • liquidsnake1989
    • Oct 2014
    • 10
    Bumping this question since it's not answered yet. Anyone have any idea?
