Oracle database monitoring question
  • bgbudragan
    • Apr 2018
    I have just registered on this forum and I am totally new in zabbix environment. I wish to test zabbix usability in area of monitoring databases ( especially oracle) and I wish from you to advice me.
    Initial idea is to test use of the zabbix for checking these metrics:
    • Database instance availability
    • listener availability
    • Tablespace usage
    • ASM diskgroup usage
    • Specific ORA- errors from alert.log file
    I have seen many plugins for oracle and other databases. Please advice me what is the best option for use to check these metrics.
    Thanks in advance!
    d.
  • zielart
    • Sep 2018
    You can use Orabbix plugin to monitor
    Tablespace usage
    ASM diskgroup usage - probably require additional configuration
    Listener availability you can check using standard port monitoring item net.tcp.listen[1521]
    For alert.log monitoring is better to use ELK or other tools for log monitoring because in zabbix you probably need to specify all "Specific ORA- errors"
    • zielart
      • Sep 2018
      You can find how to configure Orabbix on this site http://zielart.blogspot.com/2018/09/...ase-using.html
