Multiple conditions in trigger
  • dragan979
    • Apr 2018
    • 49
    I have script which returns "success","failure","abort", i configured severity warning for failed, how to set "critical" for abort ?Click image for larger version
  • BP_Vital
    • Feb 2016
    • 50
    You need different severities?
    You need another trigger for that. Clone existing, repleace "failed" with "abort" and set higher severity.
    You will have 2 triggers. If you need "information" for "success" - add third trigger.
    • dragan979
      • Apr 2018
      • 49
      Yes, i need different severities, thanks BP_Vital
      • DmitryL
        • May 2016
        • 278
        Correct, it is not possible to automatically change the severity of single trigger based on received values.
        As suggested you need to create multiple triggers.
