Zabbix-strech trigger name
  • dragan979
    • Apr 2018
    • 49
    i can't see whole trigger text, is it possible to strech it ?
  • dragan979
    • Apr 2018
    • 49
    output from picture is exit of bash script monitored by zabbix as soon as i added name to trigger body and removed it from script i was able to see all lines
    • aigars.kadikis
      • Mar 2018
      • 208
      Hi, dragan979!
      Please look for for 'items.inc.php' file on your system:
      find / -name items.inc.php
      Open and search for portion:
              // apply value mapping
              switch ($item['value_type']) {
                      case ITEM_VALUE_TYPE_STR:
                              $mapping = getMappedValue($value, $item['valuemapid']);
                      // break; is not missing here
                      case ITEM_VALUE_TYPE_TEXT:
                      case ITEM_VALUE_TYPE_LOG:
                              if ($trim && mb_strlen($value) > 20) {
                                      $value = mb_substr($value, 0, 20).'...';
                              if ($mapping !== false) {
                                      $value = $mapping.' ('.$value.')';
                              break;
                      default:
                              $value = applyValueMap($value, $item['valuemapid']);
      Replace 20 with something bigger and restart your web engine
      Be aware that after updating zabbix-web-* package these modifications needs to be redone again.
      • dragan979
        • Apr 2018
        • 49
        great, thanks a lot !!
