UserParameters, multiple items
  • dragan979
    • Apr 2018
    • 49
    I read that using LLD i can return multiple values
    this is my custom script:
    #!/bin/bash
    curl -s -H "Accept: application/json" -X GET "http://172.30.61.82:4440/api/20/project/demo/executions?authtoken=ZP9znayUp3Ktp26uQjSQGnEfTzDvqPDA"  | python -m json.tool > /tmp/1.json
    jq -r '.|[.executions[] | select(.job.name != null) ] select(.job.name|contains("test")) |  sort_by(.id)  | reverse  | .[0]  | [.status, .job.name, ."date-started".date, ."date-ended".date, .job.project] | @csv' /tmp/1.json > /tmp/1.csv
    sed 's/,/ /g' /tmp/1.csv>/tmp/st.txt
    while read -r status name startdate enddate project; do
    startdate=${startdate//\"/}
    stime=$(date -d "${startdate/T/ }" +%s)
    enddate=${enddate//\"/}
    etime=$(date -d "${enddate/T/ }" +%s)
    let elapsed=etime-stime
    if [ "$status" == "\"aborted\"" ] && [ "$elapsed" -gt 300 ]; then echo $project"-"$name-"Long-Run"
    elif [ "$status" == "\"aborted\"" ] && [ "$elapsed" -lt 300 ]; then echo $project"-"$name " Aborted"
    elif [ "$status" == "\"failed\"" ]; then echo $project"-"$name "failed-Demo"
    elif [ "$status" == "\"succeeded\"" ]; then echo $project"-"$name "success"
    elif [ "$status" == "\"succeeded\"" ] && [ "$elapsed" -gt 300 ]; then echo $project"-"$name" Takes too long"
    fi
    done</tmp/st.txt
    script output:
    Job "aa" failed
    I have another same script which monitors another job (different parameter), how to avoid creating multiple keys and triggers ?
    I read i need to create item prototype,but i'm confused what should be specified in Userparameters, what name i should specify for key and what changes in script should be specified ?
  • aigars.kadikis
    • Mar 2018
    • 208
    Hi, dragan979!
    If you have two scripts which differs only with one variable, job name in your case, then you can proceed with LLD.
    If this is the case then first you need to create another script which discovers job names only
    For example one way how to approach this thing is output all job names in separate lines like:
    echo -e "job name one\nanother job name\nthird job"
    Once you can achieve this with curl+other tools you can prepare the JSON format for LLD by piping:
    sed 's/^/{\"{#JOB}\":\"/;s/$/\"},/' | tr -cd '[:print:]' | sed 's/^/{\"data\":[/;s/,$/]}/'
    After connecting these two commands together we can get to the nice JSON string:
    {"data":[{"{#JOB}":"job name one"},{"{#JOB}":"another job name"},{"{#JOB}":"third job"}]}
    At the end this will be UserParameter for job list discover:
    UserParameter=job.list,echo -e "job name one\nanother job name\nthird job" | sed 's/^/{\"{#JOB}\":\"/;s/$/\"},/' | tr -cd '[:print:]' | sed 's/^/{\"data\":[/;s/,$/]}/'
    Discovery rule for job discover:
    And item prototype:
    {#JOB} will be your argument in Item Prototype:
    Underneath the hood you need to replace your "job name" in main script "get-job-state.sh" with $1
    Regards,
    Aigars
    • dragan979
      • Apr 2018
      • 49
      Thanks for very detaile instructions, i created trigger prototype but alert is not raised: host is attaced to template error is "Value should be in JSON format"
      This is output i get
      {"data":[{"{#JOB}":"aa"},{"{#JOB}":"test"}]}
      I validated it on https://jsonlint.com and it's valid
      no entry in agent log (set debug level to 5-no valid output), server log:
      I
      n get_value() key:'job.list'
      192320:  3319:20180406:175403.321 In get_value_external() key:'job.list'
      192321:  3319:20180406:175403.321 In zbx_popen() command:'/usr/lib/zabbix/externalscripts/job.list'
      192990:  3320:20180406:175408.019 In substitute_key_macros() data:'job.list'
      192991:  3320:20180406:175408.019 End of substitute_key_macros():SUCCEED data:'job.list'
      Script is located on agent and on Zabbix server
      [UserParameter=job.list,echo -e "aa\ntest" | sed 's/^/{"{#JOB}":"/;s/$/"},/' | tr -cd '[print:]' | sed 's/^/{"data":[/;s/,$/]}/' | /var/lib/zabbix/get-job-state.sh
       zabbix_get -s 172.30.61.82 -p 10050 -k job.list (ran from zabbix server against rundeck machine)
      "demo"-"aa" failed
      Job discovery
      Click image for larger version  Name:	1.PNG Views:	1 Size:	167.7 KB ID:	356712
      Item prototype
      Click image for larger version  Name:	1.PNG Views:	1 Size:	220.6 KB ID:	356713
      Trigger prototype
      Click image for larger version  Name:	1.PNG Views:	1 Size:	152.2 KB ID:	356714
      And getting this errorcopied script to /usr/lib/zabbix/externalscripts but don't know what jobs.list contains)
