I have these items:
Data is send by a bash script using zabbix_sender. Something like this:
Data is successfully received by all four items.
I have this trigger:
I need to see in Zabbix dashboard a problem with this description:
But instead, I have seeing a description like this:
I must not use the items logontarget, logonaccount and logonsource in the trigger expression, even knowing that would enable me to use {ITEM.VALUE<1-9>} or {ITEM.LASTVALUE<1-9>} macros in the trigger name.
In these circumstances, is it possible to get values from the items logontarget, logonaccount and logonsource and use them in the trigger name? Someone can help me with this problem description?
Thank you very much in advance.
Type: Zabbix trapper
Key: logonid
Type of information: Character
Key: logontarget
Key: logonsource
Key: logonaccount
Key: logonid
Key: logontarget
Key: logonsource
Key: logonaccount
zabbix_sender -z $SrvAddr -p $SrvPort -s $Hostname -k logontarget -o 'host01'
zabbix_sender -z $SrvAddr -p $SrvPort -s $Hostname -k logonaccount -o 'dom\user'
zabbix_sender -z $SrvAddr -p $SrvPort -s $Hostname -k logonsource -o '10.0.0.1'
zabbix_sender -z $SrvAddr -p $SrvPort -s $Hostname -k logonid -o '0xb2a32e13'
Name: {{HOST.HOST}:logontarget.last()}: Logon by {{HOST.HOST}:logonaccount.last()} from {{HOST.HOST}:logonsource.last()}
Expression: {host02:logonid.diff()}=1
OK event generation: None
PROBLEM event generation mode: Multiple
Allow manual close: Yes
Enabled: Yes
Enabled: Yes
host01: Logon by dom\user from 10.0.0.1
{host02:logontarget.last()}: Logon by {host02:logonaccount.last()} from {host02:logonsource.last()}
