Hi. I'm currently monitoring several routers I have in my network. I'm now adding them manually but I'd like to use the discovery feature to add them automatically. The problem I have is that I need to monitor only the router ping, and not all other hosts on the net.
For example: my main network is 10.0.0.0/24, I add a 10.0.10.0/24 net and I want to monitor only 10.0.10.1. Sadly being routers and with different manufacturer I cannot test services or responses, I can rely on ping only. From what I see in the Action options there's no way to filter for such option, am I right? Is there any other way to filter hosts IPs?
I'm using 3.4.4.
thanks
I'm using 3.4.4.
thanks
