No active checks
  • RonaldMcDonaldTrump
    • Jan 2018
    • 41
    No active checks
    Trying to set up a proxy I got logs
    on proxy
    proxy log: cannot send list of active checks to [192.168.99.132]: host [SRV-LAB-TRY-01] not found
    on host that I intend to monitor
    agent log: no active checks on server [192.168.99.127:10051] host [SRV-LAB-TRY-01] not found
    GUI
    Click image for larger version  Name:	Immagine.png Views:	2 Size:	44.7 KB ID:	356963
    I have some host configured without proxy and they work well.
    • Jan 2018
    • 41
    I didn't notice this error: " failed to update local proxy configuration copy: invalid field name "items.jmx_endpoint" , because of this error I figured out the mistakes. Proxy and Server were different versions
    .Click image for larger version
    • kloczek
      • Jun 2006
      • 1771
      do you have any "zabbix agent (active)" items configured on this host ar all items are still "zabbix agent" (passive) items?
        • Jan 2018
        • 41
        Active items.
        I couldn't monitor using proxy because of version incompatibility between server and proxy. Now I fixed by updating the proxy.
        • jluvs2ride
          • Jul 2015
          • 85
          What was your process for updating the proxy? I ran into the same problem on a new install using this package; zabbix-release_3.4-1+stretch_all.deb which I thought was the most recent.
