JMX integration problem
  • Filter
    Hi every one,
    I'm having problem with JMX integration. It gave the following error:
    java.io.IOException: Failed to retrieve RMIServer stub: javax.naming.ServiceUnavailableException [Root exception is java.rmi.ConnectException: Connection refused to host: 192.168.51.117; nested exception is:
    java.net.ConnectException: Connection refused (Connection refused)]
    1. I am starting java app using a .bat file (see attachement)
    2. App. start well. but zabbix not receving any data.
    3. Zabbix configuration for host is attached.
    Can anyone have any solution to this.
    Thank you.
    A lightweight Java plugin named JMXFetch is called by the Datadog Agent to connect to the MBean Server and to collect these metrics. This plugin sends metrics to the Datadog Agent using the Dogstatsd server running within the Agent prepaidgiftbalance.
    Announcement
    No announcement yet.
