UnixODBC + Active agent?
  • imarinkovic
    • Nov 2009
    • 20
    Hi friends,
    I'been working implementing UnixODBC database monitoring, but I can't make it work.
    At operating system level, I can make work unixodbc, can use isql without problems. But when I create a item, I get [unixODBC][Driver Manager]Data source name not found, and no default driver specified]
    With this, I started to check Zabbix agent logs to verify what's the problem, and I found that the new item didn't came with the new set of active checks.
    So, maybe isn't possible this combination?? Any idea?
