Action with system uptime
  • Arunas G.
    • Nov 2017
    I need to implement host system uptime in every action email. How to do it?
    Is there a way to do it like with {INVENTORY.OS} macro, or should I add sysUptime>0 in every trigger and use {ITEM.VALUEx} to get system uptime in action?
    Problem started at {EVENT.TIME} on {EVENT.DATE}
    Problem name: {TRIGGER.NAME}
    Host: {HOST.NAME} {HOST.IP}
    Severity: {TRIGGER.SEVERITY}
    Value: {ITEM.VALUE1}
    OS: {INVENTORY.OS1}
    Uptime: {HOST.NAME:sysUptime.last()} <------- Uptime reported as *UNKNOWN*
  • Atsushi
    • Aug 2013
    • 2028
    Please try use this macro.
    {{HOST.HOST}:sysUptime.last()}
    • Arunas G.
      • Nov 2017
      Atsushi - Problem still persist with {{HOST.HOST}:sysUptime.last()} - Email:
      Severity: High
      Value: 8 %
      OS: 8.0.6
      Uptime: *UNKNOWN*
      • Atsushi
        Atsushi commented
        Are you setting an item whose key value is sysUptime?
        For example, if you are using Template OS Linux, it looks like the following.
        {{HOST.HOST}:system.uptime.last()}
    • Arunas G.
      • Nov 2017
      Atsushi - Yes, key is sysUptime and it is set up properly:
      HTML Code:
      https://imgur.com/Tq7Jad3
      • Atsushi
        Atsushi commented
        Please tell me the detailed version of Zabbix you are using.
        Also, have you got the value of the item?
        Please check Monitoring -> Latest Data.
    • BP_Vital
      • Feb 2016
      • 49
      Try double brackets:
      Uptime: {{HOST.NAME}:sysUptime.last()}
      And decide either use {HOST.NAME} -Visible host name or {HOST.HOST} - regular host name.
      • Arunas G.
        Arunas G. commented
        Still sends email with *UNKNOWN*
    • Arunas G.
      • Nov 2017
      Atsushi - Zabbix 3.4.8. Latest data for item sysUptime:
      System Uptime 2018-04-18 08:39:24 23:55:17 +00:00:53
      • Atsushi
        Atsushi commented
        Please temporarily raise the debug level and let the log output why the macro can not be expanded.
