should we forget actions?
  • kopspa
    • Apr 2006
    • 19
    i'd like to know WHY actions are NOT working at all!
    and why nobody answer to this problem, this is not the first post and i'm not the first person that has this problem...
    {test.hostroc.num[apache2].last(0)}<1 is the trigger
    the action is configured, so if i do /etc/init.d/apache2 stop, the trigger become red, and the action starts...
    in fact on monitoring - actions, i can see the mail sent (and in mailbox too)
    if i do /etc/init.d/apache2 stop, on a SECOND host, configured with the same items/triggers, zabbix doesn't do nothing (triggers goes red, but no action)...
    same thing for other triggers/actions.
    why it works when it wants? it's a bug? i remember that older beta were bugged, but developers tells that the 1.1 is fixed...
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    How are your actions configured?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • kopspa
      • Apr 2006
      • 19
      Action type send messages
      Source trigger
      Conditions Trigger = "Apache"
      Send message to single user
      User admin
      subject {IPADDRESS}
      message is irrilevant
      Trigger Apache IS {test.host: proc.num[apache2].last(0)}<1 without the space... btw :
      • stever
        • Jun 2006
        • 36
        Triggers and actions are working for us.
        for example, I have this trigger defined:
        ({craig:usr.icutil.last(0)}<1)&({craig:usr.icutil. prev(0)}<1)
        And a corresponding action, with the condition Trigger = "trigger name"
        I get emails when its down. Make sure you test that your trigger is working, and not just the action.
        • kopspa
          • Apr 2006
          • 19
          all the triggers i've configured are working
          for example if i stops asterisk, or apache, or mysql or any services that zabbix is monitoring, the triggers become red (and then green if i start them)
          i've no ideas...
          • kopspa
            • Apr 2006
            • 19
            strange, if i set a actions based on 'trigger value' or 'trigger severity' it works
            • kurt
              • Aug 2005
              • 21
              before i upgraded to 1.1, i was using 1.1beta4. My database became corrupt, and after repairing it, my triggers would fire, but the actions woulndn't fire.
              So i had to re-add the triggers. once i did that, they all worked again...
              I never found an easier solution, but that one worked
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                If your database was seriously corrupt, I would suggest unloading of all data and recreation of the database from scratch.
                Alexei Vladishev
                My Twitter
