problem with sending message
  • kim_LaTrik
    • Apr 2018
    hello everyone ,
    I set up a script to send notification messages to my gmail address by following this tutorial: https://www.tecmint.com/configure-za...erts-to-gmail/
    the problem is all it's okay ,also in Report -> action log it's mentionned sent , but i didn't receive anything on my gmail
    help me please
  • LenR
    • Sep 2009
    • 1011
    Did all the test steps in the tutorial work? My first step would to be to start tcpdump to capture the gmail target host and port for another zabbix alert. You won't be able to read it if it's SSL, but if you don't see any traffic, there is a local problem.
    • kim_LaTrik
      • Apr 2018
      thank you for your response , can you please clarify exactly what i can to do for your suggestion please ?
      • tcilmo
        • Nov 2016
        • 122
        It might be easier to setup a media type in Zabbix to use the gmail SNMP servers: https://www.digitalocean.com/communi...-s-smtp-server
        More on media types: https://www.zabbix.com/documentation...ications/media - see email
        Then in your action you could specify your gmail or any other email account.
