Zabbix Polling issue
  • vnoc
    • Sep 2017
    • 115
    Hi All,
    I am configuring CPU Utilization alerts and here i am having a requirement Like
    I want to configure CPU Utilization alert as every 5 minutes 3 consecutive polls means for the 1st poll 5 min if the CPU is more than threshold alert should not be triggered and in the 3rd poll if the CPU is more than threshold alerts should be triggered. Can you please help me in fixing this.
  • tcilmo
    • Nov 2016
    • 122
    With an item update interval of 5 minutes, you could use the .avg function to accomplish this: .avg(15m)}>90 or (whatever the desired value is)
    • vnoc
      • Sep 2017
      • 115
      thanks for your reply but here my requirement will be not full filled if i do the average
      • LenR
        • Sep 2009
        • 1010
        .min(#3)>=90 (if 90 is your threshold)
        • vnoc
          • Sep 2017
          • 115
          Thanks for your reply LenR.
          How does this work . will it check 3 time and 3rd time if cpu is high u will get the alert thats it right .
          But for 5min 3 polls means how to configure
          • tcilmo
            • Nov 2016
            • 122
            The min function calculates the lowest value of an item within the defined evaluation period.
            • vnoc
              • Sep 2017
              • 115
              but my requirement is not that every 5minutes with 3 consecutive polls I need to configure resource utilization means
              • vnoc
                • Sep 2017
                • 115
                Hi Can anyone help me on the above requirement please.
                • kloczek
                  • Jun 2006
                  • 1771
                  Problem cannot be solved change key definition but in using passive agent type items and by this passive agent monitoring.
                  Passive monitoring does not scale (dosn't matter what you wil do with keys definition) and only solution is active monitoring.
