New Zabbix installation, "Specified key was too long" error
  • Bolverk
    • Apr 2018
    I'm sorry for possibly stupid question.
    I have fresly installed server with Debian 9.4 on it. Zabbix server and agent installs with no problem, agent starts and is working. I'm following this installation manual:
    I created dtabasse, but when I'm trying ti initialise it with command:
    # zcat /usr/share/doc/zabbix-server-mysql/create.sql.gz | mysql -uzabbix -p zabbix I get error:
    ERROR 1071 (42000) at line 162: Specified key was too long; max key length is 767 bytes
    MariaDB server version is:
    Server version: 10.1.26-MariaDB-0+deb9u1 Debian 9.1
    What am I doing wrong? How can I manage to get Zabbix running with my configuration?
    Thanks in advance.
  • Atsushi
    • Aug 2013
    • 2028
    Is the character set of the database set to utf8mb4?
    At the moment, please use utf8.
    ex.
    create database zabbix character set utf8 collate utf8_bin;
    • Bolverk
      • Apr 2018
      Thanks, man, You're the best! It worked. I couldn't find solution for this and I haven't had any problems with simple "create database" until now. Case closed.
      • cuongvu1992
        • May 2021
        ex.
        thank man, you save my time
        • salai
          • Nov 2020
          • 27
          I am getting the error even though I have utf8 chat set, What could be the reason for my case?
          mysql> SELECT @@character_set_database;
          | @@character_set_database |
          | utf8 |
          1 row in set (0.00 sec)
