zabbix_sender from Zabbix proxy
  • ricardo.abreu
    • Jan 2014
    Hello Everybody!
    I am new on zabbix :-)
    I have one zabbix server, and one zabbix proxy.
    On my zabbix proxy, I instaled zabbix agent too, because a I wanto do use zabbix_sender and others things...
    From my zabbix proxy, i want to putty some items (and values) in to my zabbix server, using zabbix sender.
    When a try use: zabbix_sender -c <full-path/agentd.conf> -z <zabbix server> -s <hostname equal on my web interface> -k <Key Definied on Item> -o <Value that I want> a received this message:
    zabbix_sender [21268]: DEBUG: answer [{
    "response":"success",
    "info":"processed: 0; failed: 1; total: 1; seconds spent: 0.000027"}]
    info from server: "processed: 0; failed: 1; total: 1; seconds spent: 0.000027"
    sent: 1; skipped: 0; total: 1
    I tried the similiar comand, but, directly from my zabbix server, and of course, using their differents parameters (hostname, item, value) and this worked fine.
    Are there diference when I use zabbix_sender from my zabbix proxy if I compare with others modules (agent or server) ????
    Thanks in advanced!
    Ricardo
  • mbsit
    • Sep 2012
    • 130
    Delete "-c <full-path/agentd.conf>" if you use -s, -z parameters is not needed.
    Do you have correctly defined Item with Zabbix Trapper type, and Key matched -k parameter?
    Bests,
    Grzegorz
    Wdrożenia zabbix - Warszawa
    Pozdrawiam
    Grzegorz Grabowski
    ____
    WdroĊĵenia, szkolenia, umowy serwisowe
    Warszawa - Polska
    • ricardo.abreu
      • Jan 2014
      Hi Grzegorz,
      Yeah, a i tried too without "-c <full-path/agentd.conf>". Nothing :-(
      Yes, I am usinf Item with Zabbix Trapper type and key matched with -k.
      Thanks!
      Ricardo
      • ricardo.abreu
        • Jan 2014
        More information
        Just for helping me, follow more informations:
        my agent hostname is oramgmt
        oramgmt is a proxy too
        #/usr/bin/zabbix_sender -z <my host zabbix server> -s oramgmt -k Memory.Cache -o 107G -vv
        return:
        zabbix_sender [16926]: DEBUG: answer [{
        "info":"processed: 0; failed: 1; total: 1; seconds spent: 0.000029"}]
        info from server: "processed: 0; failed: 1; total: 1; seconds spent: 0.000029"
        This comand is from oramgmt
        Attached my Zabbix Item Screen (item.png).
        Is there one kind of configuration on host that influence in zabbix_sender ?
        Thanks,
        Ricardo
