Monitoring Switch Temp
  • Lezer
    • Apr 2018
    Hello!
    I need to create an alert in zabbix,
    Im using the following SNMP OID: .1.3.6.1.4.1.9.9.13.1.3.1.3.1008
    The point is that it does not give me any error but on the other hand no value is being shown
    There you have the config
    And here there is the graph
    Thank you!
  • tcilmo
    • Nov 2016
    • 122
    First, have you verified that you can get data (values) manually with snmpwalk from the device?
    • Lezer
      • Apr 2018
      Yes, it show me the correct Temps.
      • Lezer
        • Apr 2018
        Does nobody knows¿
