Disable Host after trigger or any better approach
  • atlantun
    • May 2018
    Hi Guys,
    I'm stuck trying to remove/disable hosts after a trigger event.
    Host is created : call zabbix 'host.create' api to add the host and assign it to a template A with additional macros etc...
    I have control of the create part.
    I have an external check item : calling an api
    and I have a trigger with a condition on the value returned from the api
    == all of this works fine.
    I would like to remove the host from zabbix ( or disable ) when a trigger condition is met.
    I only see actions such as send message and so.
    - i have tried to change my trigger into a discovery rule ( since I see the possibility to add/remove host ) but this is not very clear to me what a discovery rule is.
    Please let me know how to achive this
    Thank you
  • LenR
    • Sep 2009
    • 1010
    You can use the Remote Command operation to run an api script. Instead of current host, point to a utility system for scripts. I run the Zabbix web on a separate host, so I use it for my script system. In prior releases I used this method to set inventory to automatic. You can pass the host name macro to the API.
    • atlantun
      • May 2018
      Perfect
      thank you
      • Artak
        • May 2018
        Hi Guys,
        I stuck to create host on zabbix via API
        The below is my JSON
        $Jsonbody2= @'
        "jsonrpc": "2.0",
        "method": "host.create",
        "params": {
        "host": "TestHost",
        "interfaces": [
        "type": 1,
        "main": 1,
        "useip": 1,
        "ip": "192.168.80.80",
        "dns": "",
        "port": "10050"
        "groups": [@{groupid: "95"}]
        "templates": [
        "templateid": "10273"
        "auth": "",
        "id": 2
        Response always keeps the same:
        -32500 Application error. No permissions to referred object or it does not exist!
        Pls support
        Artak.
