LLD SNMP interface
  • mlabelle
    • Dec 2013
    LLD SNMP interface
    Hi all,
    I want to use zabbix to discover a large datacenter switch network (more 1000 switches and more 15000 physical ports).
    I did some test in my lab. I want to do the SNMP LLD to discover the interface, but only the interface has an AdminStatus = 1 (Up). When i do this regex, I loose the interface name.
    Any idea how to solve this problem
  • Colttt
    • Mar 2009
    • 878
    please take a look at this:
    otherwise, please let show us you config (screenshots)
    Debian-User
    Sorry for my bad english
    • mlabelle
      • Dec 2013
      Just a little more context....
      If i take the the zabbix SNMP interface template, the discovery rule is on the SNMP interface description (IF-MIB::ifDescr). All items prototype will use the {#SNMPVALUE} for the name of all keys
      If only want to discover all interface with AdminStatus = 1 (Up), I just change the discovery item with IF-MIB::ifAdminStatus with a filter. I have only the interface up but the {#SNMPVALUE} is always equal to 1. Zabbix do an auto increment to all interface. You can understand with a Cisco Nexus 7000, is not very helpfull.
      This is my problem.
      • rogeriofox
        • Nov 2013
        This is my problem.
        I'm the same problem with Palo Alto. I'm studying for resolv this issue. If I resolv will post here!
