Problem configuring Web Monitor
  • gleach
    • Jan 2014
    I am new to zabbix an I am having an issue configuring a web monitor correctly
    My webapp uses Basic/Windows authentication.
    Once authenticated, the first time you logon, you are prompted with a EULA of sorts. Once accepted, you receive a cookie so that you bypass it on future requests and access the main application.
    The question is since the EULA only appears once, how do I configure the monitor to submit the cookie and bypass the page, or each time, press the "accept" button assuming each test would remove the cookie.
    The post data is as follows when you accept the terms:
    __EVENTTARGET=&__EVENTARGUMENT=&__LASTFOCUS=&__VIE WSTATE=%2FwEPDwULLTE5NTQyNDIxNjcPZBYCZg9kFgICAQ9kF gICAQ9kFgJmD2QWBAIBD2QWAgIBD2QWBAIBD2QWAgIBDw8WAh4 HVmlzaWJsZWhkZAIHD2QWBgIBD2QWBGYPFgIeC29ubW91c2Vkb 3duBbQBcG9wbWVudV9oaWRlTW9yZU9wdGlvbnMoJ2N0bDAwX1R pdGxlUGxhY2VIb2xkZXJfQ29udGVudEhlYWRlcl9SZXBvcnRFe HBvcnRfUHVibGlzaE1lbnVfbWVudU9wdGlvbnMnLCdjdGwwMF9 UaXRsZVBsYWNlSG9sZGVyX0NvbnRlbnRIZWFkZXJfUmVwb3J0R Xhwb3J0X1B1Ymxpc2hNZW51X3NjcmVlbkludmlzaWJsZScpZAI BD2QWAmYPZBYCZg8WAh4Hb25jbGljawW1AXBvcG1lbnVfaGlkZ U1vcmVPcHRpb25zKCdjdGwwMF9UaXRsZVBsYWNlSG9sZGVyX0N vbnRlbnRIZWFkZXJfUmVwb3J0RXhwb3J0X1B1Ymxpc2hNZW51X 21lbnVPcHRpb25zJywnY3RsMDBfVGl0bGVQbGFjZUhvbGRlcl9 Db250ZW50SGVhZGVyX1JlcG9ydEV4cG9ydF9QdWJsaXNoTWVud V9zY3JlZW5JbnZpc2libGUnKTtkAgMPZBYEZg8WAh8BBbIBcG9 wbWVudV9oaWRlTW9yZU9wdGlvbnMoJ2N0bDAwX1RpdGxlUGxhY 2VIb2xkZXJfQ29udGVudEhlYWRlcl9SZXBvcnRFeHBvcnRfRXh wb3J0TWVudV9tZW51T3B0aW9ucycsJ2N0bDAwX1RpdGxlUGxhY 2VIb2xkZXJfQ29udGVudEhlYWRlcl9SZXBvcnRFeHBvcnRfRXh wb3J0TWVudV9zY3JlZW5JbnZpc2libGUnKWQCAQ9kFgJmD2QWA mYPFgIfAgWzAXBvcG1lbnVfaGlkZU1vcmVPcHRpb25zKCdjdGw wMF9UaXRsZVBsYWNlSG9sZGVyX0NvbnRlbnRIZWFkZXJfUmVwb 3J0RXhwb3J0X0V4cG9ydE1lbnVfbWVudU9wdGlvbnMnLCdjdGw wMF9UaXRsZVBsYWNlSG9sZGVyX0NvbnRlbnRIZWFkZXJfUmVwb 3J0RXhwb3J0X0V4cG9ydE1lbnVfc2NyZWVuSW52aXNpYmxlJyk 7ZAIFD2QWBGYPFgIfAQWwAXBvcG1lbnVfaGlkZU1vcmVPcHRpb 25zKCdjdGwwMF9UaXRsZVBsYWNlSG9sZGVyX0NvbnRlbnRIZWF kZXJfUmVwb3J0RXhwb3J0X0VtYWlsTWVudV9tZW51T3B0aW9uc ycsJ2N0bDAwX1RpdGxlUGxhY2VIb2xkZXJfQ29udGVudEhlYWR lcl9SZXBvcnRFeHBvcnRfRW1haWxNZW51X3NjcmVlbkludmlza WJsZScpZAIBD2QWAmYPZBYCZg8WAh8CBbEBcG9wbWVudV9oaWR lTW9yZU9wdGlvbnMoJ2N0bDAwX1RpdGxlUGxhY2VIb2xkZXJfQ 29udGVudEhlYWRlcl9SZXBvcnRFeHBvcnRfRW1haWxNZW51X21 lbnVPcHRpb25zJywnY3RsMDBfVGl0bGVQbGFjZUhvbGRlcl9Db 250ZW50SGVhZGVyX1JlcG9ydEV4cG9ydF9FbWFpbE1lbnVfc2N yZWVuSW52aXNpYmxlJyk7ZAIHD2QWBgIBDxBkDxYRZgIBAgICA wIEAgUCBgIHAggCCQIKAgsCDAINAg4CDwIQFhEQBQnEjGXFoXR pbmEFAmNzZxAFB0RldXRzY2gFAmRlZxAFEM6VzrvOu863zr3Ou c66zqwFAmVsZxAFB0VuZ2xpc2gFAmVuZxAFCEVzcGHDsW9sBQJ lc2cQBQlGcmFuw6dhaXMFAmZyZxAFCEl0YWxpYW5vBQJpdGcQB Qnml6XmnKzoqp4FAmphZxAFCe2VnOq1reunkAUCa29nEAUJTGl ldHV2acWzBQJsdGcQBQZwb2xza2kFAnBsZxAFClBvcnR1Z3XDq nMFAnB0ZxAFDtCg0YPRgdGB0LrQuNC5BQJydWcQBQ1TbG92ZW7 FocSNaW5hBQJzbGcQBQhUw7xya8OnZQUCdHJnEAUM566A5L2T5 Lit5paHBQJ6aGcQBQznuYHpq5TkuK3mlocFBXpoLVRXZxYBAgN kAgMPFgIeA3NyYwUHZW4uaHRtbGQCBQ8PFgIeBFRleHQFK0kgY WNjZXB0IHRoZSB0ZXJtcyBpbiB0aGUgbGljZW5zZSBhZ3JlZW1 lbnRkZGTvmpX0HHGkd7Q5cp3Fu4R3HqWp0lcL5Ec93LVGFHp2Y w%3D%3D&ctl00%24ScrollerLeft=0&ctl00%24ScrollerTop =0&ctl00%24ContentPanePlaceHolder%24LanguageSelec t or=en&ctl00%24ContentPanePlaceHolder%24AcceptLink= I+accept+the+terms+in+the+license+agreement
    I assume as the Viewstate will change each time that this isn't required in the Post field. I have tried just adding ctl00%24ContentPanePlaceHolder%24AcceptLink=I+acce pt+the+terms+in+the+license+agreement but that doesn't work.
    Gerrard
  • jan.garaj
    • Jan 2010
    • 506
    It look like a case for Zabbix 2.2 and its new feature Retrieving data from a webpage
    You will need at least 2 steps.
    1st step - standard GET request with custom regexp variables for retrieving data e.g. __VIEWSTATE, __EVENTTARGET, &__EVENTARGUMENT, __LASTFOCUS, ... ({viewstate}=regex:<your_regexp>, ... )
    And you will use these parsed variables in 2nd step as POST variables:
    __VIEWSTATE={viewstate}&__EVENTTARGET={eventarget} ....
    Maybe you will need parse variables again for next step.
    I don't have any experience with this feature at the moment, so please share your solution.
    Anyway, you can't inject cookie or cookie variable in standard Zabbix webmonitoring. But you always can create your own curl script with persistent cookies and then you can only parse data from script to Zabbix.
    Read more:
    In several previous articles in the Zabbix 2.2 series we already discussed several improvements for web monitoring – the ability to template it, customise the amount of retries and the ability to specify an HTTP proxy on the scenario level. There’s more – in 2.2 it will also be possible to parse content from a […]
