Help dimensions folder
  • Thomas90
    • May 2018
    • 11
    Hi all, sorry for questions but I'm newmbie using zabbix.
    I want to generate a trigger alarm when a folder located in D:\Zabbix_Test is over 500Mb.
    I've used the Expression VFS.FS.SIZE but without any useful result. How can I do?
    I've tried this, but i cant add any trigger: https://www.zabbix.com/forum/zabbix-...-a-folder-size
    Thank you
  • BP_Vital
    • Feb 2016
    • 50
    try using vfs.dir.size[D:\Zabbix_Test]
    • Thomas90
      • May 2018
      • 11
      Hi Vital, i've tried but it says "error expressions"
      • Atsushi
        Atsushi commented
        Did you create items?
        And, To use vfs.dir.size[], it must be Zabbix 3.4 or later.
      • Thomas90
        Thomas90 commented
        my mistakes :P i've not created item
    • Thomas90
      • May 2018
      • 11
      Ok wait! i've put into items and not into triggers (For sure ) and now it looks the correct value. Now i've to create trigger...
      • Thomas90
        • May 2018
        • 11
        Love you all. Solved! Thanks!
