Obtaining values from zabbix database
  • eleonb94
    • May 2018
    We seek to process monitoring data of some particular items in the database, but filtering by itemid in the Trends or History table tells us that there is no data for that item, however when plotting that item from the zabbix web interface the graphic shows values ​​from quite some time ago, so it must be stored somewhere, but we have not found where it can be. Also there are some items that do have their values ​​in the tables of the database, only they are not the ones that interest us for the work we are doing. Please,any suggestions will be well received.
  • kloczek
    • Jun 2006
    • 1771
    • eleonb94
      • May 2018
      When trying to make any request it gives us the following error, both when doing it remotely and directly on the server, the version of zabbix that we are using is 3:
      {"jsonrpc":"2.0","error":{"code":-32700,"message":"Parse error","data":"Invalid JSON. An error occurred on the server while parsing the JSON text."},"id":null}
      There is a possibility that with this API you will receive the data, even if they do not appear by directly surveying the database?
      • eleonb94
        • May 2018
        Is it possible that the data is in the history-cache and not in the history table of the database? If so, in what way can I obtain the data from that cache to process them?
        • kloczek
          • Jun 2006
          • 1771
          Error message is clear.
          Your input json string has some syntax issue(s).
          • eleonb94
            • May 2018
            I don't understand what errors can be, if the syntax is copying directly from the documentation to test the API. {"jsonrpc":"2.0","method":"apiinfo.version","id":1 ,"auth":null,"params":{}}
            • kloczek
              • Jun 2006
              • 1771
              $ curl --silent -X POST -H 'Content-Type: application/json' -d '{"jsonrpc":"2.0","method":"apiinfo.version","params":{"filter":{"params":[]}},"id":0}' http://localhost/api_jsonrpc.php; echo
              {"jsonrpc":"2.0","result":"3.4.9","id":0}
              $ curl --silent -X POST -H 'Content-Type: application/json' -d '{"jsonrpc":"2.0","method":"apiinfo.version","params":{"filter":{"params":[]}},"auth":null,"id":0}' http://localhost/api_jsonrpc.php; echo
              params must be not the record ("{}"} but the array ("[]").
              • eleonb94
                • May 2018
                the syntax error was fixed with that, but now the output of the command gives me: <p>The requested URL /api_jsonrpc.php was not found on this server.</p> it seems that the API is not available on my server
