Failed to accept incoming connection
  • qbecerra
    • May 2018
    Hi
    I've found in the following log file:
    /var/log/zabbix/zabbix_agentd.log
    the strings you can see below:
    ... failed to accept an incoming connection: connection from ---- rejected, allowed hosts: "127.0.0.1"
    The blurred IP in the log screenshot is the zabbix_server's fixed assigned IP in LAN
    Show I worry about this? And where can I change this so I don't get this error ?
  • Atsushi
    • Aug 2013
    • 2028
    Have you set the IP address of the Zabbix server as the value of Server in zabbix_agentd.conf?
    • qbecerra
      • May 2018
      I've checked the zabbix_agentd.conf
      Should I change 127.0.0.1 to the server's LAN ip address, right?
