Previous string value in trigger description
  • markz
    • Apr 2018
    need help to show previous string value in trigger name (description). Zabbix v3.4.9
    Trigger name:
    Firmware has changed on {HOST.NAME} from {{ITEM.VALUE2}.regsub("\d+(\.\d+)*",\0)} to {{ITEM.VALUE1}.regsub("\d+(\.\d+)*",\0)}
    Trigger Expression:
    ({Template SNMP Mikrotik:routeros.version.change()}>0) and ({Template SNMP Mikrotik:routeros.version.strlen(#2)}>0)
    but this doesn't work, it shows the same value. Example:
    Information 21.05.2018 00:00:26 21.05.2018 01:00:26 RESOLVED RB850Gx2-1 Firmware has changed on RB850Gx2-1 from 6.42.2 to 6.42.2
    2018-05-21 02:00:26    6.42.2
    2018-05-21 01:00:26    6.42.2
    2018-05-21 00:00:26    6.42.2
    2018-05-20 23:00:26    6.42.1
    2018-05-20 22:00:26    6.42.1
  • Engraf
    • Sep 2014
    • 41
    The macro {ITEM.VALUE<1-9>} provides an ITEM value that used in trigger expression but not expression value itself ( i.e. host:key but not {host:key.func(param)} ).
    I do not see how you can get previous value in trigger name. It has a limited set of supported macros (see manual).
