Items increment in Zabbix 2.2
  • FineMEDIA
    • May 2018
    I need info where in Zabbix 2.2 is stored last item id.When i added new item to database with sql query i have this info: '[Duplicate entry '123110' for key 'PRIMARY']' . I don't want to remove sql added items.
    Best regards,
  • Atsushi
    • Aug 2013
    • 2028
    Have you added values directly to the database?
    If you want to add directly in the database, you need to add data that is consistent.
    It is not recommended to manipulate the database directly.
    Depending on the item, you may be able to add item values using the zabbix_sender command.
    You can also create a file and register the value of an item with a specific time stamp.
    • FineMEDIA
      • May 2018
      Thanks for response. Now i need information how can i repair this. I don;t wanna remove inserted data from database.
      • kernbug
        • Feb 2013
        • 329
        Hi
        Backup and try to replace table, example:
        Tables or result sets in a database usually contain duplicate records. While duplicates are generally allowed, there are situations where it is necessary to prevent them. In such cases, it becomes essential to identify and remove duplicate records
        • FineMEDIA
          • May 2018
          Do you know where intems_id couter are stored? In database or some config file?
          • kernbug
            • Feb 2013
            • 329
            Database, items table, also get a backup and check foreign keys before doing something.
