Problem with Overwiew
  • pietro54
    • Feb 2011
    • 112
    I got problem with my ovieview, but only with windows section.
    I see error like bellow:
    Argument 1 passed to CTriggerDescription::expandReferenceMacros() must be an array, boolean given, called in /var/www/html/include/classes/helpers/trigger/CTriggerDescription.php on line 109 and defined [include/classes/helpers/trigger/CTriggerDescription.php:159]
    Argument 1 passed to CTriggerDescription::expandUserMacros() must be an array, boolean given, called in /var/www/html/include/classes/helpers/trigger/CTriggerDescription.php on line 137 and defined [include/classes/helpers/trigger/CTriggerDescription.php:190]
    I found thread but without any answer.
    I got
    Zabbix 2.0.4
    Redhat 6.3
    Postgres 9.1.2
    How can i solve the problem?
    It`s very uncomfortable to see this on my screen.
    Please help/advice.
  • Bomby
    • Jun 2018
    hi
    I have the exact same problem can you tell me how it can be solved and what is due? Thank you in advance I report my mistake
    • Argument 1 passed to CTriggerDescription::expandReferenceMacros() must be an array, boolean given, called in /usr/local/share/zabbix/include/classes/helpers/trigger/CTriggerDescription.php on line 109 and defined [include/classes/helpers/trigger/CTriggerDescription.php:159]
    • Argument 1 passed to CTriggerDescription::expandUserMacros() must be an array, boolean given, called in /usr/local/share/zabbix/include/classes/helpers/trigger/CTriggerDescription.php on line 137 and defined [include/classes/helpers/trigger/CTriggerDescription.php:190]
    • and defined [include/classes/helpers/trigger/CTriggerDescription.php:159]
    • kernbug
      • Feb 2013
      • 329
      I got
      Zabbix 2.0.4
      Redhat 6.3
      Postgres 9.1.2
      Please help/advice.
      Consider updating of the Zabbix installation.
      Also you can do:
      1. Disable all of the triggers;
      2. Enable 1 by 1 to find bad one.
