How to monitor Zabbix itself with IPMI?
  • TheRiderU
    • May 2018
    • 31
    I try to monitor Zabbix itself with IPMI but all i get is unkown error: [cannot connect to IPMI host: [16777411] Unknown error 16777411]. if it possible to monitor Zabbix itself with IPMI? because i try 127.0.0.1 IP and 192.168.x.x IP for the iDRAC card in the Zabbix server.
    Thanks for your help.
  • kernbug
    • Feb 2013
    • 329
    Hello, TheRiderU
    Could you ping iDRAC IP address from Zabbix server? Are they in the same network segment?
    • TheRiderU
      • May 2018
      • 31
      Originally posted by kernbug
      Hello, TheRiderU
      Yes i can ping the iDRAC IP address from the Zabbix Server.
      • kernbug
        • Feb 2013
        • 329
        How did you set up IPMI in Zabbix and iDRAC itself?
        Please, make a screenshot of the zabbix IPMI setup and execute this command from zabbix server console:
        ipmitool –vI lan -H192.168.X.X –U <user> -a sdr list
        • TheRiderU
          • May 2018
          • 31
          Something is wrong with this command it return the manual for the command
          • TheRiderU
            • May 2018
            • 31
            Nevermind i read "-vI" as "-v1"
            but the command returns
            Get Auth Capabilities command failed
            Error: Unable to establish LAN session
            Error: Unable to establish IPMI v1.5 / RMCP session
            • TheRiderU
              TheRiderU commented
              put i can ping the 192.168.x.x IP from the zabbix server console
          • TheRiderU
            • May 2018
            • 31
            When i try only this part from the Command i get an output:
            Temp | disabled | ns
            • TheRiderU
              TheRiderU commented
              man i forget the command part: ipmitool -a sdr list
          • TheRiderU
            • May 2018
            • 31
            Ok i solved the Problem, i forgot to turn on IPMI to LAN at the iDRAC card. now it works fine. thx for your help.
            • kernbug
              • Feb 2013
              • 329
              thx for your help.
              You're welcome if it was helpful!
