triggering by bit from value
  • kicho
    • Jan 2014
    Is it possible to create trigger monitoring one bit from item value ? assume item value is unsigned integer 1 byte
    Is there a function returning integer or floating part from value ?
  • ArtemK
    • May 2013
    • 232
    band function supported since 2.2
