Zabbix template.get => {"jsonrpc":"2.0","result":[],"id":0}
  • fabian1233
    • Jun 2018
    I'm currently trying to use the zabbix api to get a list of all template names and id's, but unfortunately I'm getting the following response: {"jsonrpc":"2.0","result":[],"id":0}
    An request looks ways like this:
    class zabbix
        private $authID = "<valid auth id>";
        private $url = "<url zur api>"
        private function sendRequest($data)
            $query = json_encode($data);
            echo $query."<br><br>";
            $ch = curl_init($this->url);
            curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "POST");
            curl_setopt($ch, CURLOPT_POSTFIELDS, $query);
            curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
            curl_setopt($ch, CURLOPT_HTTPHEADER, array(
                'Content-Type: application/json'
            return json_decode(curl_exec($ch), true);
        public function getTemplates()
            $request = array("jsonrpc" => "2.0",
                    "method" => "template.get",
                    "params" => array(
                        "output" => "simple",
                        "filter" => array(
                            "name" => array("Template OS Linux")
                    "id" => 0,
                    "auth" => $this->authID
            print_r($this->sendRequest($request));
    Anyone has an idea what the problem is, or how I can debug this?
    Best regards,
    Fabian
  • kernbug
    • Feb 2013
    • 329
    Originally posted by fabian1233
    Request JSON:
    "jsonrpc":"2.0",
    "method":"template.get",
    "params":{
    "output":"extend",
    "sortfield":"name",
    "id":0,
    "auth":"a1b03e140e57468b8579155c4449d509"
    Best regards,
    Fabian
    Hi, fabian1233
    You get an empty result. According to the official documentation you must specify requested "params": https://www.zabbix.com/documentation...e/template/get
    • kloczek
      • Jun 2006
      • 1771
      Feel free to check SH shell example about how to call template.get zabbix API
      zapish - Zabbix API SHell binding. Contribute to kloczek/zapish development by creating an account on GitHub.
      • fabian1233
        • Jun 2018
        Originally posted by kernbug
        Hi, fabian1233
        I've just updated the request json to:
        "jsonrpc":"2.0",
        "params":{
        "output":"simple",
        "filter":{
        "host":[
        "Template OS Linux"
        "id":0,
        "auth":"d088f5eae1ea81e620cc1b05cf534353"
        But stell got an empty result. Any idea, what the problem is?
        #EDIT:
        The full code looks similar to this:
        class zabbix
                        "params" => array(
                            "filter" => array(
                        "id" => 0,
        • kernbug
          • Feb 2013
          • 329
          Tested on fresh install in AWS with OS X HS as client:
          Get Auth token:
          curl  -H "Content-Type: application/json-rpc" -X POST  http://x.x.x.x/api_jsonrpc.php -d '{"jsonrpc":"2.0","method":"user.login","params":{ "user":"Admin","password":"zabbix"},"auth":null,"id":0}'
          Answer from Zabbix API:
          {"jsonrpc":"2.0","result":"[COLOR=#FF0000]6fad8b8d9ddf367e55a21a56dca469b5[/COLOR]","id":0}
          Get Templates:
          curl  -H "Content-Type: application/json-rpc" -X POST  http://x.x.x.x/api_jsonrpc.php -d '{"jsonrpc": "2.0",    "method": "template.get","params": {"output": "extend","filter": {"host": ["Template OS Linux","Template OS Windows"]}},"auth": "[COLOR=#FF0000]6fad8b8d9ddf367e55a21a56dca469b5[/COLOR]","id": 1}'
          {"jsonrpc":"2.0","result":[{"proxy_hostid":"0","host":"Template OS Linux","status":"3","disable_until":"0","error":"","available":"0","errors_from":"0","lastaccess":"0","ipmi_authtype":"-1","ipmi_privilege":"2","ipmi_username":"","ipmi_password":"","ipmi_disable_until":"0","ipmi_available":"0","snmp_disable_until":"0","snmp_available":"0","maintenanceid":"0","maintenance_status":"0","maintenance_type":"0","maintenance_from":"0","ipmi_errors_from":"0","snmp_errors_from":"0","ipmi_error":"","snmp_error":"","jmx_disable_until":"0","jmx_available":"0","jmx_errors_from":"0","jmx_error":"","name":"Template OS Linux","flags":"0","templateid":"10001","description":"","tls_connect":"1","tls_accept":"1","tls_issuer":"","tls_subject":"","tls_psk_identity":"","tls_psk":""},{"proxy_hostid":"0","host":"Template OS Windows","status":"3","disable_until":"0","error":"","available":"0","errors_from":"0","lastaccess":"0","ipmi_authtype":"-1","ipmi_privilege":"2","ipmi_username":"","ipmi_password":"","ipmi_disable_until":"0","ipmi_available":"0","snmp_disable_until":"0","snmp_available":"0","maintenanceid":"0","maintenance_status":"0","maintenance_type":"0","maintenance_from":"0","ipmi_errors_from":"0","snmp_errors_from":"0","ipmi_error":"","snmp_error":"","jmx_disable_until":"0","jmx_available":"0","jmx_errors_from":"0","jmx_error":"","name":"Template OS Windows","flags":"0","templateid":"10081","description":"","tls_connect":"1","tls_accept":"1","tls_issuer":"","tls_subject":"","tls_psk_identity":"","tls_psk":""}],"id":1}
