question on "zabbix-ldap-sync"
  • kovas
    • Dec 2012
    • 39
    I am new to linux.
    I have downloaded zabbix-ldap-sync and properly configured zabbix-ldap.conf file.
    I successfully installed pyzabbix:
    sudo pip install pyzabbix
    But if I execute:
    ./zabbix-ldap-sync -f zabbix-ldap.conf
    I get:
    ImportError: No module named 'pyzabbix'
    Any suggestions?
    Many thanks
    k
  • kovas
    • Dec 2012
    • 39
    If I execute:
    source venv/bin/activate
    I get:
    2018-06-12 11:16:30,417 - INFO - JSON-RPC Server Endpoint: http://1.1.1.1/zabbix/api_jsonrpc.php
    2018-06-12 11:17:01,521 - INFO - Connected to Zabbix API Version 3.2.5
    Traceback (most recent call last):
    File "./zabbix-ldap-sync", line 90, in <module>
    main()
    File "./zabbix-ldap-sync", line 87, in main
    zabbix_conn.sync_users()
    File "/home/user/zabbix-ldap-sync/lib/zabbixconn.py", line 344, in sync_users
    ldap_users = self.ldap_conn.get_group_members(eachGroup)
    File "/home/user/zabbix-ldap-sync/lib/ldapconn.py", line 154, in get_group_members
    attrlist=attrlist)
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/ldapobject.py", line 852, in search_s
    return self.search_ext_s(base,scope,filterstr,attrlist,at trsonly,None,None,timeout=self.timeout)
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/ldapobject.py", line 846, in search_ext_s
    return self.result(msgid,all=1,timeout=timeout)[1]
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/ldapobject.py", line 738, in result
    resp_type, resp_data, resp_msgid = self.result2(msgid,all,timeout)
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/ldapobject.py", line 742, in result2
    resp_type, resp_data, resp_msgid, resp_ctrls = self.result3(msgid,all,timeout)
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/ldapobject.py", line 749, in result3
    resp_ctrl_classes=resp_ctrl_classes
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/ldapobject.py", line 756, in result4
    ldap_result = self._ldap_call(self._l.result4,msgid,all,timeout, add_ctrls,add_intermediates,add_extop)
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/ldapobject.py", line 329, in _ldap_call
    reraise(exc_type, exc_value, exc_traceback)
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/compat.py", line 44, in reraise
    raise exc_value
    File "/home/user/zabbix-ldap-sync/venv/lib/python3.5/site-packages/ldap/ldapobject.py", line 313, in _ldap_call
    result = func(*args,**kwargs)
    ldap.REFERRAL: {'info': 'Referral:\nldap://company.local/CN=User1,OU=Users,DC=company,DC=local', 'desc': 'Referral'}
    Any advice would be great
    Many thanks
    • kernbug
      • Feb 2013
      • 329
      But if I execute:
      k
      sudo ./zabbix-ldap-sync -f zabbix-ldap.conf
      or
      pip install pyzabbix #without sudo
      Why this happens: by default pip modules are user-local.
      ldap.REFERRAL: {'info': '(<censored company name>)'}
      You need no check LDAP connection properties.
      • kovas
        • Dec 2012
        • 39
        thanks kernbug
        • kovas
          • Dec 2012
          • 39
          thanks kernbug
