450 max monitored host with Zabbix 3.4 - on going problem for 6 months
  • mellis
    • Oct 2017
    • 145
    Afternoon
    I am have problems getting the numbe rofmonitored host over 450 with version 3.4.7.
    Currently i have 454 host with 44000 items needing 353 values per second processing
    I run on two servers, one with 8GB ram, 4 vCPUs, this has the zabbix-server and Zabbix-GUI web server on it, the other has 40GB ram 4vCPU a MySQL 5.7,.22 database.
    My problem seem to be that after a hour or less all the host go to an unreachable state. I do not see errors in the zabbix_server.log and if i query the database direct they are still avaiable. I do see some mysql errors
    2018-06-12T15:21:54.221486Z 0 [Note] InnoDB: page_cleaner: 1000ms intended loop took 4914ms. The settings might not be optimal. (flushed=1111 and evicted=0, during the time.)
    2018-06-12T15:35:06.444614Z 0 [Note] InnoDB: page_cleaner: 1000ms intended loop took 4742ms. The settings might not be optimal. (flushed=2016 and evicted=0, during the time.)
    2018-06-12T15:41:22.550261Z 0 [Note] InnoDB: page_cleaner: 1000ms intended loop took 4450ms. The settings might not be optimal. (flushed=1612 and evicted=0, during the time.)
    2018-06-12T15:50:48.065072Z 0 [Note] InnoDB: page_cleaner: 1000ms intended loop took 4800ms. The settings might not be optimal. (flushed=1923 and evicted=0, during the time.)
    2018-06-12T15:56:36.151414Z 0 [Note] InnoDB: page_cleaner: 1000ms intended loop took 6321ms. The settings might not be optimal. (flushed=3368 and evicted=0, during the time.)
    If i do a restart on the zabbix-server these will clear up for again 30mins to an hour.
    attached are some graphs of the zabbix processes.
    zabbix_server.conf
    StartPollers=464
    # StartIPMIPollers=0
    StartPreprocessors=36
    StartPollersUnreachable=48
    StartTrappers=56
    # StartPingers=1
    # StartDiscoverers=1
    # StartHTTPPollers=1
    StartTimers=16
    StartEscalators=10
    # JavaGatewayPort=10052
    # StartJavaPollers=0
    # VMwareFrequency=60
    # VMwarePerfFrequency=60
    # VMwareCacheSize=8M
    # VMwareTimeout=10
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    # StartSNMPTrapper=0
    # ListenIP=127.0.0.1
    # HousekeepingFrequency=1
    MaxHousekeeperDelete=100000
    # SenderFrequency=30
    CacheSize=512M
    CacheUpdateFrequency=900
    StartDBSyncers=54
    HistoryCacheSize=1024M
    HistoryIndexCacheSize=128M
    TrendCacheSize=128M
    ValueCacheSize=256M
    Timeout=30
    # TrapperTimeout=300
    # UnreachablePeriod=45
    # UnavailableDelay=60
    # UnreachableDelay=15
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    my.cnf
    show_compatibility_56 = ON
    performance_schema
    innodb_data_home_dir=/home/mysql
    innodb_flush_log_at_trx_commit = 2
    innodb_file_per_table = 1
    innodb_buffer_pool_instances = 23
    innodb_buffer_pool_size = 22G
    innodb_page_cleaners=64
    innodb_flush_method = O_DIRECT
    innodb_doublewrite = 0
    innodb_checksum_algorithm=NONE
    innodb_read_io_threads = 64
    innodb_write_io_threads = 64
    tmp_table_size = 42M
    max_heap_table_size = 42M
    max_allowed_packet = 1024M
    thread_cache_size = 14
    join_buffer_size = 2048M
    sort_buffer_size = 4M
    read_rnd_buffer_size = 4M
    query_cache_size = 0
    query_cache_type = 0
    query_cache_limit = 2M
    max_connections = 724
    wait_timeout = 9600
    interactive_timeout = 9600
    datadir=/home/mysql
    socket=/var/lib/mysql/mysql.sock
    # Disabling symbolic-links is recommended to prevent assorted security risks
    symbolic-links=0
    #logging stuff
    log-error=/var/log/mysqld.log
    slow_query_log = 1
    slow_query_log_file = /var/log/slow_quiery.log
    pid-file=/var/run/mysqld/mysqld.pid
  • kernbug
    • Feb 2013
    • 329
    The same thread: https://www.zabbix.com/forum/zabbix-...m-for-6-months
