Monitoring Cisco ASA VPN Traffic/State
  • lpossamai
    • Jun 2018
    • 119
    Hi all,
    I've got a Zabbix 3.4 server running and a Cisco ASA 5520. I am trying to monitor the traffic over a site-to-site VPN connection. I came across this POST (https://www.zabbix.com/forum/zabbix-...ec-vpn-tunnels), but as it is quite old, I decided to ask the question again...
    Do you guys know how I can monitor a VPN Traffic through Zabbix using SNMP v2?
    Cheers
  • lpossamai
    • Jun 2018
    • 119
    So.... after spending some time I managed to get this working with the query_asa_lan2lan.pl script.
    My Setup 2018:
    Zabbix 3.4
    CentOS 7 64 Bits
    1. download it from this thread.
    2. Copy the script to the "externalscripts" folder in your Zabbix Server. Usually "/usr/lib/zabbix/externalscripts/"
    3. Install any Perl dependencies you may need
    use POSIX;
    use Switch;
    use Net::SNMP;
    4. Test your script
    perl /usr/lib/zabbix/externalscripts/query_lan2_lan_cisco_final.pl community ASA_IP_ADDRESS ASA get RX PEER_IP_ADDRESS
    Example:
    My ASA FW IP: 192.168.1.1
    VPN Peer IP Address: 203.120.120.12
    perl /usr/lib/zabbix/externalscripts/query_lan2_lan_cisco_final.pl public 192.168.1.1 ASA get RX 203.120.120.12
    5. Create a new Template via the Web Interface
    6. Inside that new template, create a new Item as follow:
    The key value is:
    query_lan2_lan_cisco_final.pl["community","cisco-asa-ip","ASA","get","RX","peer-ip-address"]
    query_lan2_lan_cisco_final.pl["public","192.168.1.1","ASA","get","RX","203.120.120.12"]
Name:	Screenshot from 2018-06-13 15-07-00.png
    • kernbug
      • Feb 2013
      • 329
      Cool guide, thank you.
      • lpossamai
        • Jun 2018
        • 119
        UPDATE:
        To get a better-looking graph, you may wanna tweak Zabbix.
        When creating the Item, go to the Preprocessing tab and add:
        Units = bps
        Change per second
        Custom Multiplier | Value is 8.
        The graph before the change looked like:
        After the change it is looking like:
Name:	Screenshot from 2018-06-18 10-15-55.png
        • Paulo Santos
          • Sep 2018
          Hi.
          Is it possible run this script in zabbix_proxy enviroment?
          Tks
          PS
