Juniper syslog zabbix trapper monitoring idea.
  • TheRiderU
    • May 2018
    • 31
    Hello community,
    I have my Juniper firewall and this device sends me a syslog report to any server i want, it don't exist a syslog file on the juniper itself.
    So i need to monitor this syslog report for specific word patterns.
    so how can i do that? anyone have an idea?
    my idea was that i send the syslog report to a Zabbix server and then monitor it with zabbix_agent(active) with log[] or logrt[].
  • kernbug
    • Feb 2013
    • 329
    Originally posted by TheRiderU
    Hello community,
    Hi
    Install and configure syslogd/syslog-ng/etc on Zabbix Server to receive syslog from Juniper hosts. And you will be able to monitor log files from Zabbix.
    • TheRiderU
      • May 2018
      • 31
      Originally posted by kernbug
      Hi
      and the item or trigger will look like what? wich type i need to choose?
      • kloczek
        • Jun 2006
        • 1771
        Hello community,
        Bettrer would be switch to use SNMP traps.
        • kernbug
          • Feb 2013
          • 329
          In all cases it's not bad to have logs from network devices.
          • TheRiderU
            • May 2018
            • 31
            So how can i filter the logs with the Zabbix items or triggers. wich type i need to choose?
            • kernbug
              • Feb 2013
              • 329
              kloczek is right, you need to use SNMP checks/traps. Syslog logs are useful in case of problem analysis.
