Dual WAN monitoring
  • David.Stubbs
    • May 2017
    Dual WAN monitoring
    We have two WAN connections for our datacenter. One is a blended circuit across several isp's from our Datacenter itself, The other is a standalone connection thru another ISP. Lately we have been having odd latency issues with hosted desktops. We are wanting to find the best way to check the integrity of both WAN connections IE dropped packets or sudden latency issues. The Zabbix server is configured with dual NICs and the firewall is configured for each NIC to go out of a specific WAN port. I'm sure someone has had to deal with something similar to this in the past. I have dug around and found no good way to specify to Zabbix which Interface it should use for a check
  • michael_zanatta
    • Dec 2022
    Hi, does anybody got any solution of that?
    • Markku
      • Sep 2018
      • 1784
      There is no Zabbix-controlled way to say "use this NIC for any network traffic related to this item". Zabbix works as an application on the system where it runs.
      You can still use whatever tricks are available in the underlying operating system. The most common (and easiest) is using specific routing for specific destination addresses, meaning like "traffic to destination X (where X is an IPv4 or IPv6 network) should use interface Y and next-hop Z".
      Markku
