Connection problems
  • fabian1233
    • Jun 2018
    Connection problems
    currently I have some issues with the connection of the zabbix server to it's clients, resulting in missing data and so on. In the server log I can see for example:
    32542:20180615:090230.314 Zabbix agent item "gpu.fan-speed[2, AMD]" on host "2a1.test.de" failed: first network error, wait for 15 seconds
    32548:20180615:090249.915 resuming Zabbix agent checks on host "2a1.test.de": connection restored
    32546:20180615:090554.706 Zabbix agent item "agent.ping" on host "2a1.test.de" failed: first network error, wait for 15 seconds
    32548:20180615:090724.686 resuming Zabbix agent checks on host "2a1.test.de": connection restored
    The latency is under 1ms, its a local very fast connection. Any guesses what the cause can be, and how to fix it?
  • kernbug
    • Feb 2013
    • 329
    Hello
    Could you provide the following information?
    • Zabbix server performance
    • Zabbix internal process busy
    • Zabbix data gathering process busy
    • Zabbix cache usage
    • Number of unreachable hosts/unsupported items
    • Active or Passive proxies
    • Active or Passive agents
    • Zabbix Server conf
    • Zabbix Proxy conf
    • Zabbix Version
