Using Host Inventory Name as Visible Name
  • openconcepttech
    • Jun 2018
    Hey Guys,
    New here in the forum and a bit above average in the Zabbix scene. I need some help. I have everything configured OK in 3.2 (Thanks to SNMP Builder)
    WHAT I WANT TO ACCOMPLISH:
    Using the macro of {INVENTORY.NAME<1-9>}, I would like to use a similar macro for showing the "Visible Name" of what the Inventory screen has.
    Reason:
    We have customers that sometimes require a radio swap or have canceled customers, or etc. Its easier than having to go in and rename each hosts configuration each time we have a change as such.
    If anyone has any kind of solution, please let me know. If not, Move this post to the feature request Sub-Forum please.
  • kernbug
    • Feb 2013
    • 329
    Originally posted by openconcepttech
    Hey Guys,
    Reason:
    Hi
    {INVENTORY.NAME<1-9>} location based (trigger/internal notification): https://www.zabbix.com/documentation...ed_by_location
    With Zabbix API you can change required fields on CRM/Billing update: https://www.zabbix.com/documentation/3.2/ru/manual/api
    • syntax53
      • Mar 2018
      • 40
      FYI, here is the script I wrote for updating the visible name from the inventory and a couple other things via the API and python: https://pastebin.com/DvcWyC5r
