Server offline installation
  • MortenA
    • Jun 2018
    I want to install the Zabbix monitor-server on a server which does not have any internet connections. Can someone direct me to a guide to follow, or a pre-configured package ? I copied all the zabbix-files over, only to find there is a bunch of dependencies required.
    Regards.
    Morten
  • kernbug
    • Feb 2013
    • 329
    Regards.
    Morten
    Hi
    Operation system?
    • MortenA
      • Jun 2018
      I want to install on CentOS 7.
      Looking at my offline repo, it seems it only has version 2.2. Perhaps I can check if I can get 3.4 in a newer repo-update.
      • kloczek
        • Jun 2006
        • 1771
        None of the zabbix software components requires to have "internet connections".
        • Atsushi
          • Aug 2013
          • 2028
          Even if there is no Internet connection, you can install any necessary packages.
          However, in addition to the Zabbix package, there are many dependent packages, so it takes time to align them.
          In this case, we will install Zabbix 3.4.10 for MySQL on CentOS 7.5.1804.
          The package to be obtained from the Zabbix repository is as follows.
          zabbix-agent-3.4.10-1.el7.x86_64.rpm
          zabbix-server-mysql-3.4.10-1.el7.x86_64.rpm
          zabbix-web-3.4.10-1.el7.noarch.rpm
          zabbix-web-mysql-3.4.10-1.el7.noarch.rpm
          fping-3.10-1.el7.x86_64.rpm
          iksemel-1.4-2.el7.centos.x86_64.rpm
          The package to be acquired from the CentOS 7 repository is the following package.
          OpenIPMI-libs-2.0.23-2.el7.x86_64.rpm
          OpenIPMI-modalias-2.0.23-2.el7.x86_64.rpm
          apr-1.4.8-3.el7_4.1.x86_64.rpm
          apr-util-1.5.2-6.el7.x86_64.rpm
          dejavu-fonts-common-2.33-6.el7.noarch.rpm
          dejavu-sans-fonts-2.33-6.el7.noarch.rpm
          fontpackages-filesystem-1.44-8.el7.noarch.rpm
          gnutls-3.3.26-9.el7.x86_64.rpm
          httpd-2.4.6-80.el7.centos.x86_64.rpm
          httpd-tools-2.4.6-80.el7.centos.x86_64.rpm
          libX11-1.6.5-1.el7.x86_64.rpm
          libX11-common-1.6.5-1.el7.noarch.rpm
          libXau-1.0.8-2.1.el7.x86_64.rpm
          libXpm-3.5.12-1.el7.x86_64.rpm
          libevent-2.0.21-4.el7.x86_64.rpm
          libjpeg-turbo-1.2.90-5.el7.x86_64.rpm
          libpng-1.5.13-7.el7_2.x86_64.rpm
          libtool-ltdl-2.4.2-22.el7_3.x86_64.rpm
          libxcb-1.12-1.el7.x86_64.rpm
          libxslt-1.1.28-5.el7.x86_64.rpm
          libzip-0.10.1-8.el7.x86_64.rpm
          mailcap-2.1.41-2.el7.noarch.rpm
          net-snmp-libs-5.7.2-33.el7_5.2.x86_64.rpm
          nettle-2.7.1-8.el7.x86_64.rpm
          php-5.4.16-45.el7.x86_64.rpm
          php-bcmath-5.4.16-45.el7.x86_64.rpm
          php-cli-5.4.16-45.el7.x86_64.rpm
          php-common-5.4.16-45.el7.x86_64.rpm
          php-gd-5.4.16-45.el7.x86_64.rpm
          php-ldap-5.4.16-45.el7.x86_64.rpm
          php-mbstring-5.4.16-45.el7.x86_64.rpm
          php-mysql-5.4.16-45.el7.x86_64.rpm
          php-pdo-5.4.16-45.el7.x86_64.rpm
          php-xml-5.4.16-45.el7.x86_64.rpm
          t1lib-5.1.2-14.el7.x86_64.rpm
          trousers-0.3.14-2.el7.x86_64.rpm
          unixODBC-2.3.1-11.el7.x86_64.rpm
          If you also install mariadb-server, you also need to install the package that mariadb-server and mariadb-server depend on.
          • lallhands@gmail.com
            • Nov 2019
            Is there a comparable list of required packages for offline installation for Ubuntu 18.0.4 documented somewhere? I need to install an Ubuntu Zabbix server remotely on a network that has no Internet access besides my ssh. Thanks!
