Save Download traffic size after reset ethernet traffic
  • omid1979
    • Nov 2016
    • 33
    hi all ,
    I want to record all my traffic Usage via server's ehternet port
    I using command cat /proc/net/dev and cut traffic send/ recive via ethernet like below
    cat /proc/net/dev | grep eth1.1 | awk '{print $1,$2,$10}'
    eth0 26841759 1221608
    Receive: 26841759
    Transmit : 1221608
    I can save this two parameter to zabbix without problem , but IF I reset the server or disable/enable ehternet port this counter was reset
    how can I add new data ( after reset or reboot the server ) to last valid data (befor reset or reboot the server )?
    I don't want to reset ethernet Traffic download data
    how can I record new data in zabbix Item via formula (for example if newdata<olddata then newdata=olddata+newdata)
  • kernbug
    • Feb 2013
    • 329
    Originally posted by omid1979
    hi all ,
    Receive: 26841759
    Transmit : 1221608
    Hi
    If you have N servers your "tool" is Netflow protocol for traffic accounting and statistics. Or use local counter for accumulated calculated value in cron (script + custom user.parameter in Zabbix agent).
    • omid1979
      • Nov 2016
      • 33
      Originally posted by kernbug
      Hi
      Thanks so much , know I use script +userparameter to do that ,
      but If I want to use netflow how can I do ? can I monitor traffic statistics per port for each device using zabbix ?
      • kernbug
        • Feb 2013
        • 329
        Netflow consist of 3 main components: collector, sensor, analyzer. You need sensor(for example fprobe on linux hosts, network hardware mostly support out the box) and collector (for example flow-tools) from which you could export statistics to Zabbix. It's a little bit complicated for this topic, but Netflow is more than total traffic statistics.
