Zabbix Active Agent does not work from the frontweb
  • Arcocide
    • Apr 2015
    • 85
    Hello everyone,
    I would like to set up an "Active Agent" monitoring but I do not recover anything from the frontweb.
    But when I run the command manually I have a result :
    zabbix_get -s 192.168.253.41 -p 10050 -k system.run ["curl -sSlL http://192.168.253.41:12900/system/lbstatus"]
    ALIVE
    Why from the web interface I have nothing and no error?
    Thank you for your feedback.
  • Arcocide
    • Apr 2015
    • 85
    Ok I find something. I can't to use Zabbix Agent Active for any hosts. I think that the problem become from my Zabbix server but I don't know what !
    • Atsushi
      • Aug 2013
      • 2028
      If you use active check, it is necessary for Zabbix agent side to be able to connect to Zabbix server.
      By default, port number 10051 is used.
      Is the connection status to LISTEN on Zabbix server?
      Are you permitted by Zabbix server's Firewall setting?
      • Arcocide
        • Apr 2015
        • 85
        Ok I find my problem. The name "hostname" in the config file was wrong.
