Can we create/edit items, hosts, triggers, etc, using CLI from Zabbix server?
  • zayalaksme
    • Jun 2018
    Instead of gui I want to use cli for creating/editing hosts, items, triggers, etc. Can you please help me on this. Atleast i need show commands to know the configured parameters.
  • kernbug
    • Feb 2013
    • 329
    No CLI interface, use Zabbix API (JSON) with any programming language: https://www.zabbix.com/documentation/3.4/manual/api
    To check Zabbix Server configuration look at /etc/zabbix/zabbix_server.conf.
    • kloczek
      • Jun 2006
      • 1771
      And other advice: instead creating create/edit items, hosts, triggers, etc just use templates and create anything you want in templates.
      • kmstrube81
        • May 2018
        • 11
        As kern was saying you can use the API and cURL to use as a defacto CLI or use PHP etc to access the API
        An example cURL command would be- curl -H "Content-Type: application/json" -X POST -d '{your zabbix api call}' http://your.zabbix.server/api_jsonrpc.php
