Hello, I have some problem with monitoring JBoos with JMX interface. This problem I resolve with recompile zabbix_java_gateway on file (JMXItemChecker.java)
Old:
String conn = request.getString(JSON_TAG_CONN);<br
int port = request.getInt(JSON_TAG_PORT);<br
url = new JMXServiceURL("service:jmx:rmi:///jndi/rmi://" + conn + ":" + port + "/jmxrmi");<br
jmxc = null;<br
mbsc = null;<br
New:
Integer remoting = new Integer("7777");<br
int retval = remoting.compareTo(port);<br
if (retval == 0)<br
{<br
url = new JMXServiceURL("service:jmx:remoting-jmx://" + conn + ":" + port);<br
}<br
else
{<br
}<br
jmxc = null;<br
mbsc = null;<br
I compile this like that
./configure --enable-server --enable-agent --with-mysql --with-libcurl --with-libxml2 --enable-java
And added the necessary libraries:
jboss-as-remoting-7.2.1.Final-redhat-10.jar
jboss-logging-3.1.2.GA-redhat-1.jar
jboss-logmanager-1.4.3.Final-redhat-1.jar
jboss-marshalling-1.3.18.GA-redhat-1.jar
jboss-marshalling-river-1.3.18.GA-redhat-1.jar
jboss-remoting-3.2.16.GA-redhat-1.jar
jboss-sasl-1.0.3.Final-redhat-1.jar
jcl-over-slf4j-1.7.2-redhat-1.jar
jul-to-slf4j-stub-1.0.1.Final-redhat-1.jar
log4j-jboss-logmanager-1.0.2.Final-redhat-1.jar
remoting-jmx-1.1.0.Final-redhat-1.jar
slf4j-api-1.6.1.jar
slf4j-api-1.7.2-redhat-1.jar
slf4j-ext-1.7.2-redhat-1.jar
xnio-api-3.0.7.GA-redhat-1.jar
xnio-nio-3.0.7.GA-redhat-1.jar
Now when I try monitor JBoss with zabbix proxy, data is not sent to the server Zabbix. The logs zabbix_java_gateway can see that the data are retrieved from the JBoss correctly, while the logs zabbix_proxy there is no trace to be executed any traffic between the proxy and the server zabbix. Of course zabix proxy there is on different host.
Please give me some advice what's wrong?
Regards
Mick
Old:
jmxc = null;<br
mbsc = null;<br
New:
if (retval == 0)<br
{<br
}<br
else
{<br
}<br
jmxc = null;<br
mbsc = null;<br
slf4j-api-1.6.1.jar
Regards
Mick
