Zabbix on FreeNAS
  • afagund
    • Feb 2018
    • 10
    Zabbix on FreeNAS
    Can someone help me understand the procedure below? I did not understand the section "under System - init/shutdown scripts". Where should that section be executed? Looks like something is missing or not well detailed.
    Join the friendly and open Zabbix community on our forums and social media platforms.
    Thanks!
    Andre
  • kloczek
    • Jun 2006
    • 1771
    You need to say a bit with what you have problems to understand
    • afagund
      • Feb 2018
      • 10
      I did not understand where those commands from that section should be executed. Is that on FreeNAS shell? If that is on FreeNAS, where that mount point and files comes from?
      • LenR
        • Sep 2009
        • 1011
        It looks like it wants you to put a config on some mount you create, then it will copy that to /etc/zabbix in each startup. This looks like the old startup/shutdown before service or systemd. I think you put things in the order you want them started.
        Maybe post the file for an example.
        • kernbug
          • Feb 2013
          • 329
          Nope, FreeNAS=FreeBSD, no systemd! From web-interface you can install only jail/pbi apps, but from the console view full freedom of the FreeBSD
          Login to the FreeNAS using SSH, open /usr/local/etc/pkg/repos/local.conf and set:
          local: {
          url: «file:///usr/ports/packages»,
          enabled: false
          Next find /usr/local/etc/pkg/repos/FreeBSD.conf:
          FreeBSD: {
          enabled: yes
          From now run pkg update:
          Updating FreeBSD repository catalogue…
          FreeBSD repository is up to date.
          All repositories are up to date.
          Here you are, find zabbix (man pkg) and install!
          Another option to monitor FreeNAS using SNMP: https://share.zabbix.com/storage-devices/freenas-11
          • afagund
            afagund commented
            This procedure works great. Thanks kernbug!
        • afagund
          • Feb 2018
          • 10
          I will test the procedure and will get back here with an update.
          Thanks!
          Andre Fagundes
          • afagund
            • Feb 2018
            • 10
            Here is the final procedure I followed. This works great on FreeNAS-11.1-U5. Just had issue with Zabbix template. I was not able to find a FreeNAS template which uses agent for monitoring - just SNMP. For that reason I am using the FreeBSD template, which gives a basic monitoring.
            vi /usr/local/etc/pkg/repos/local.conf
            local: {
            enabled: false
            vi /usr/local/etc/pkg/repos/FreeBSD.conf
            FreeBSD: {
            enabled: yes
            pkg update
            pkg seach zabbix
            pkg install zabbix34-agent-3.4.8
            vi /etc/rc.conf
            # Enable zabbix agent
            zabbix_agentd_enable="YES"
            cp /etc/local/zabbix34/zabbix_agentd.conf.sample /etc/local/zabbix34/zabbix_agentd.conf
            service -e | grep zabbix
            service zabbix_agentd start
            vi /etc/local/zabbix34/zabbix_agentd.conf
            Server=<zabbix_server_ip>
            Thanks!
            Andre Fagundes
            • mykolaq
              • May 2015
              • 69
              and after update your zabbix agent will be purged. Use snmp template and dont worry. IMHO
              • Weiss
                • May 2019
                After reboot FreeNAS zabbix_agent is mising.
                Pls help.
